Страница 32 от 148 ПърваПърва ... 2230313233344282 ... ПоследноПоследно
Резултати от 466 до 480 от общо 2218
Media Player Popcorn Hour NMT A-110
  1. Moderator
    Aug 2006
    #466
    Re: POPCORN Hour A-110 ...По-добрата алтернатива или...!?
    Ето ви лог с промените след последната официална версия, която най-вероятно са ти сложили:
    Firmware Update section:
    Release Version : 01-17-090116-15-POP-402-000 (full update)
    Release Date : 16 January 2009, 17:50 +8GMT
    Comments :
    1. New NMT apps 00-17-090115-15-POP-402
    2. Fixed HDD spin-up during standby
    3. Slight adjustment of subtitle position
    4. Fixed slow loading of HTML pages
    Release Version : 01-17-090109-15-POP-402-000 (full update)
    Release Date : 09 January 2009, 20:05 +8GMT
    Comments :
    1. Atheros USB WiFi added support for TP-Link v2 stick
    2. Various IDX/SUB fixes
    3. Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc)
    4. Fixed after ISO playback, screen goes blank when framerate sync kicks in
    5. Browser image caching fix, should fix some YAMJ crashes or no image issue.
    6. Removed IDX/SUB support which looks like may drag longer due to various issues.
    Release Version : 01-17-081224-15-POP-402-000 (full update)
    Release Date : 26 December 2008, 23:45 +8GMT
    Comments :
    1. Fix for wrong character rendered in Thai subtitle
    2. Framerate sync fixes
    - Use 59.94 for NTSC when matching content detected.
    - Fixed incorrect data shown on infobar.
    3. IDX/SUB supported (first implementation, only external IDX/SUB)
    Release Version : 01-17-081218-15-POP-402-000 (full update)
    Release Date : 19 December 2008, 22:25 +8GMT
    Comments :
    1. Temporarily removed disk maintenance function
    2. Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list
    3. Immediate response to STOP during Internet video streaming
    4. Framerate sync
    - switch to NTSC(60Hz) when selected mode not applicable.
    (previously, it will follow TV mode selected)
    5. Fixed MKV H264 L4.1 pixelated video issue
    6. Improved fileplayer speed
    7. Fine-tune Web Service UI
    8. Fixed info bar lost text after pause
    9. Fixed TS file playback failure (38.15Mibitps_1080p30_1920x1080_48Khz384kbpsAC3.ts)
    broken since 01-17-081113 firmware.
    Release Version : 01-17-081204-15-POP-402-000 (full update)
    Release Date : 05 December 2008, 19:40 +8GMT
    Comments :
    1. New NMT apps 00-17-081204-15-POP-402
    2. Fixed faded color for jpeg at 360-deg rotation
    3. Video bookmark:
    - 10 bookmarks available now
    - Press stop to bookmark the last video playback
    - Press enter / play with focus on bookmarked clip to resume
    4. Fixed "check disk" interrupt handling
    5. Fixed recovery kernel no red screen displayed
    Release Version : 01-17-081128-15-POP-402-000 (full update)
    Release Date : 28 November 2008, 19:25 +8GMT
    Comments :
    1. New NMT apps 00-17-081127-15-POP-402
    2. Gaya modification
    - HTTP download manager
    - File player hide "recycle bin" folder
    - Fixed "torrent schedule page not working"
    3. Web Services page modification
    - Fixed a "save/remove service" bug
    - Now able to customise JPG/BMP icon
    4. "Check disk" feature added (Maintance ==> Disk Maintance Tool)
    5. More proper way to handle MKV H.264 profile and vlevel.
    6. Modified infobar UI (height, spacing and text displayed)
    7. Fade-In Fade-out effect added for photo transition
    8. Enable large jpeg rotation. (downscale before rotate)
    9. Modified progressive zoom and pan in ISO/IFO playback
    10. Changed default subtitle font size to 28 and Y offset to 10.
    11. Torrent client is now by default tranmission (btpd removed).
    12. Fixed 'TV MODE' + '3' key handling error
    13. Fixed "Internet radio slow IR response"
    14. Fixed "Cannot stream MPEG from UPnP AV server, liveTV"
    15. Fixed ".pls file unable to start when playback locally (HDD/SMB/NFS)"
    16. Fixed "TS with stream6 as teletext playback cause out of memory"
    17. Fixed "Exception handling in SSA subtitle parsing"
    18. Fixed some WiFi issues
    19. Fixed some Thai subtitle issues
    20. Fixed "more accurate mpeg1/2 bitrate info display"
    21. Known issues
    - DVD: sometimes rough rendering when panning
    - NDAS is temporarily disabled
    - Checkdisk issues
    - don't press stop when "Stopping NMT app"
    - "visual off" happen after start check disk - tracing. To recover, press "Power" key twice.
    - TORRENT: users must finish incomplete BTPD download before installing new NMT apps, as transmission cannot inherit BTPD download
    Release Version : 01-17-081113-15-POP-402-000 (full update)
    Release Date : 14 November 2008, 19:32 +8GMT
    Comments :
    1. Same NMT apps 00-17-081030-15-POP-402
    2. Thai subtitle support
    3. Fixed file copy failed from HDD to SMB/NFS with names containing whitespace
    4. Fixed UPnP AV server playall issue broken in previous 01-17-081106 release
    5. Fixed Samba server halts after device name change
    6. Removed EXT2 option for NMT installation
    - Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly
    7. Additional symbols can be input from key "1"
    Release Version : 01-17-081106-15-POP-402-000 (full update)
    Release Date : 07 November 2008, 19:10 +8GMT
    Comments :
    1. New NMT apps 00-17-081030-15-POP-402
    2. Browser
    - Improvement on font engine character rendering (30% speed up)
    - local drives faster navigation
    - press item number (using numeric key) will jump to the page where the item is located
    3. Hebrew translation added
    4. New Web Services UI
    - customizable icon feature with browse image utility (need NMT apps)
    - Known issue: Translation incomplete
    5. Improved SMB server startup time
    6. Improved browsing time for SMB client.
    7. Video playback
    - Bookmark/resume for mono single playback (only one at moment)
    - Auto framerate synchronisation
    - VCD *.DAT playback fixed using soft demux
    - Removed up/down keys as prev/next track
    8. Atheros USB WiFi stability fixes
    9. Fixed HDMI display output blackout issue for auto EDID
    10. NDAS support
    - Known issue: cannot run with NMT apps running; fixing
    11. Discrete RC (Logitech) scancode fix
    12. Fixed Hebrew SRT subtitle containing invalid character
    13. Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed
    14. TV Type setting for DVD playback
    - the TV type setting is now working for DVD video playback
    (4:3 and 16:9 only, 16:10 will treat as 16:9)
    15. DVD Menu
    - new popup menu if MENU key on PCH remote controller is pressed
    - user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu
    16. SMB client fixes
    - Fixed name query hostname resolution picked up wrong IP address from the IP list
    17. Updated network share and webservices language packs.
    18. Webservices, bug fixes on customizable service icon with browse feature.
    19. Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt
    20. Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC)
    21. Disable incorrect video MPEG1/2 VBR display.
    22. Fixed incorrect framerate info for video playback (*.mov, *.mp4).
    23. Fixed subtitle parsing with BOM (UTF8 support only)
    24. Fixed video bitrate calculation error (less 1 packet every second)
    #467
    При мен след гасене харддиска си продължава да работи. Коя от всички да сложа и най-интересното как да я ъпдейтна тази красавица А-110?
  4. Moderator
    Aug 2006
    #468
    Цитат Първоначално публикувано от soon
    Бета версиите са САМО за А100. Всички тестове и разботки се правят за А100, изкарват официална версия за А100 и чак тогаваслед няколко дена пускат официална версия за А110.
    Както е видно в последната бета са оправили гасенето на диска:
    Тествано и е оправено. Тази версия е Release Candidate 3 така че до 1-2 седмици ще има официална версия със всички тези подобрения.
  5. Member Аватара на kaloman
    Sep 2008
    #469
    Цитат Първоначално публикувано от ethernall
    Някой беше писал, че и сега ако се спре Casgle сървиса хара не се пуска сам, но не съм го проверил още.
    Ми аз проверих- за сега мълчи харда.
    Jan 2009
    #470
    А някой дали има информация как се справя този плеър със субтитрите?
    http://www.hdplex.net/
  7. Junior Member
    Jan 2009
    #471
    Цитат Първоначално публикувано от vbred
    Не виждам други устройства в Network, това ми е проблема
    Принципно, ето тук (http://www.networkedmediatank.com/sh....php?tid=11334), в пост N7 e описано какво трябва да направя, и уж съм направил същите настройки като на картинката.
    Но когато стигна до map-ването на network drive, не се вижда нито едно устройство, което трябва да избера.
    Не става и с \\<ip>\<drive> директно в text box-a.
    В същото време, през media share го виждам и съответно съм го добавил.
    Проблем ли е да вървят всички сървъри на плеъра? Товарят ли го?
    Up-вам си поста, че мина известно време.
    Някой може ли да ми помогне да видя хард диска на попкорна през Виста 32bit?
    SAMBA-та ми е пусната и двете устройства са ми в една група.
    Мерси на всички предварително.
    Mar 2008
    #472
    Имаш ли ping до popcorn-a?
  10. Moderator
    Aug 2006
    #473
    ping имаш ли към устройството?
    Firewall-a изключен ли от Control Panel - Windows Firewall?
  11. Junior Member
    Jan 2009
    #474
    Дам, имам ping. Качвам си през ftp и stream-вам с myiHome.
    Windows-кият firewall е изключен, работи този на AVG-то. Пробвах и него да изключа, но пак не го виждам.
  12. Moderator
    Aug 2006
    #475
    А с \\192.168.1.104 пробва ли? Само че с твоя вътрешен адрес.
  13. Junior Member
    Jan 2009
    #476
    Ако имаш предвид през ie, да, пробвах го, не става
    Dec 2008
    #477
    Цитат Първоначално публикувано от kita_vgg
    здравей аз имам kaiboer k100,не знам дали те интересува този модел,но аз със субтитрите до сега съм нямал проблеми,чете всичко,като мелачка е!!!единствения проблем е DTS.трябва ресивър??
  16. Moderator
    Aug 2006
    #478
    Там има около 10 плеъра. Кой точно?
  17. Тук е от
    Jan 2009
    #479
    До lazarus18:
    Имах предвид този (http://www.hdplex.net/egreat-eb-m32b...5th-batch.html),объркал съм линка в предишния ми пост.
    До Terminator3:
    Откъде си го взел и за колко,ако не е тайна.И,най-вече ме интересува дали плейва и Flac,за DTS-a няма проблем защото аз имам ресийвър и ако е ок със субтитрите и Flaca,бих си го поръчал веднага.К-100 не е този който гледах,но ако вс наистина е ок с него той дори е и по ефтин...
    Jan 2009
    #480
    А може би поне К-200,защото на К-100 май диска му е външен и това да не стане проблем при възпроизвеждане на 1080p.Ако и това сте пробвали,моля да споделите!!!
    А за този модел(http://www.hdplex.net/iobox-100hd-ne...-shipping.html ),дори пише че има и меню на български...
  1. Media Player - Popcorn Hour 2014(всички модели)/FAQ на първа страница
    От jovanoty във форум Мултимедийни плейъри
    Отговори: 841
    Последно: 12-02-24, 10:50
  2. Media Player Popcorn Hour NMT A-110 - част 2
    От kod във форум Мултимедийни плейъри
    Отговори: 236
    Последно: 26-11-18, 22:50
  3. Продавам Media Player Popcorn Hour NMT A-110
    От patzi във форум Продава
    Последно: 08-12-14, 18:33
  4. Popcorn Hour A400 Media Player мултимедиен плеър
    От asiurib във форум Продава
    Последно: 27-08-14, 17:19
  5. Media Player Popcorn Hour A-200
    От popcornhour във форум Мултимедийни плейъри
    Отговори: 777
    Последно: 15-07-13, 21:26
