Вижте резултатите от анкетата: Коя е най-добрата марка телевизор според вас?
456. Не можете да гласувате в тази анкета
  • Sharp
    30 6.58%
  • Sony
    85 18.64%
  • Philips
    82 17.98%
  • Panasonic
    111 24.34%
  • Toshiba
    10 2.19%
  • Hitachi
    2 0.44%
  • Samsung
    75 16.45%
  • LG
    49 10.75%
  • друга
    12 2.63%
Страница 255 от 443 ПърваПърва ... 205245253254255256257265305 ... ПоследноПоследно
Резултати от 3,811 до 3,825 от общо 6641
Помощ за избор на LCD/Plasma телевизори - 2009
    #3811
    **********************/files/M8BRQFC8/...T2WXX.rar.html
    LE32B55* T315HW02 V2,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch,FHD, 4U-Lamp, w/o inverter
    (Second Panel : LTF320HA09,SSCZAI,8bit,32inch,16.7M,16:9,0.3635(H)*0.36375(w),0 to +50,12V,SPVA 72%,32 inch FHD)
    LE37B55* T370HW02 V,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD, 10S-Lamp, w/o inverter
    LE40B55* V400H1-L05,8bits,40inch,16.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch,FHD, w/o inverter
    (Second Panel : LTF400HA08,SSDZAZ,8bit,40inch,1.67M,16:9, 0.461(H)*0.461(W),0 to +50,12V,SPVA 72%,40inch FHD 60Hz)
    LE46B55* V460H1-L06,8bits,46inch,16.7M,16:9,0 to +50,12V,Flip Pixel, 72%,46 inch, FHD
    (Second Panel : LTF460HA06,SSEZAV,8bit,46inch,16.7M,16:9,0.53025(H)*0.53025
    (W,0 to +50,12V,SPVA 72%,AG3)
    LE32B65* T315HW02 V3,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch, FHD,4U-Lamp, w/o inverter, 120Hz(MEMC)
    LE37B65* T370HW02 VE,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD,10S-Lamp, w/o inverter, 120Hz(MEMC)
    LE40B65* LTF400HF09,8bit,40inch,1.07B,16:9,0.46125(H)*0.15375(w,0 to +50,12V,SPVA 72%,40 inch FHD
    LE46B65* LTF460HF03,SSEZFT,8bit,46inch,1.07B,16:9,0.53025(H)*0.53025(w,0 to +50,12V,SPVA 75% ZBD,46 inch FHD
    LE55B65* V546H1-L01,CM54H11A,10bits,54.6inch,1073.7M,16:9,0 to +50,12V,Flip Pixel,72%,54.6 inch, FHD, 120Hz(MEMC), S/C
    LE40B62* V400H1-LH3,CM40H13A,10bits,40inch,1073.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch, FHD, w/o inverter, 120Hz(MEMC)
    LE46B62* T460HW03 V5,AU46H35,8bit,46 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,46 inch,FHD, 20S-Lamp, 120Hz(MEMC)
    LE52B62* LTF520HE09,SSNZEI,8bit,52inch,1.06B,16:9,0.6(H)*0.6(w),0 to +50,12V,SPVA72%,FHD 120Hz(AG)
    LE40B75* V400H1-LH3,CM40H13A,10bits,40inch,1073.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch, FHD, w/o inverter, 120Hz(MEMC)
    LE46B75* T460HW03 V5,AU46H35,8bit,46 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,46 inch,FHD, 20S-Lamp, 120Hz(MEMC)
    LE52B75* LTF520HE09,SSNZEI,8bit,52inch,1.06B,16:9,0.6(H)*0.6(w),0 to +50,12V,SPVA72%,FHD 120Hz(AG)
    Mar 2009
    #3812
    Цитат Първоначално публикувано от adtomov
    Привет besny :-)
    Не знам как точно следиш този форум, но на няколко пъти съобщих, че кодът SQ01 не е това, което беше. Знам го от ЛИЧНИ наблюдения. По-рано (миналата година), с този код се обозначаваха S-PVA матрици, най-често с 10-битови контролери, нещо, добре познато. Тази година, под този код, Samsung представя като старите, така и една нова матрица, като единствената снимка на това, което съм видял в модела LE-40B750, беше публикувана първо тук:....
    Съжалявам, ако съм подвел някой с матрицата но говорим за 40B650
    Този форум за твоя информация го следя с четене, т.к. не съм достатъчно компетентен, както явно ти си мислиш, че си, но по писаното точно тук - http://forum.setcom.bg/index.php/topic,37709.40.html между втората и третата картинка пише : "..гледайте да пише SS08 или SQ01 това е S-PVA матрица на Samsung
    срещат се В650 с АА02-AUO и В651 с SS08- S-PVA
    BN указва матриците за Led Edge подсветка /BN02 в 46B7020/
    гледате третия ред -Version- CN, AA, SQ, и т.н. ..."
    Отново съжалявам, че съм запомнил правилно както е точно е написано в поста на hristoslav2, защото точно това съблюдавах преди да направя моя избор. При по-голямо желание от твоя страна, за да потвърдя "ЛИЧНИТЕ ТИ НАБЛЮДЕНИЯ" лично ще се обадя до international office на Samsung да сваля съмненията за абривиатурата на матрицата.
    Успех!
  4. Member Аватара на adtomov
    Apr 2008
    #3813
    Цитат Първоначално публикувано от besny
    ... При по-голямо желание от твоя страна, за да потвърдя "ЛИЧНИТЕ ТИ НАБЛЮДЕНИЯ" лично ще се обадя до international office на Samsung да сваля съмненията за абривиатурата на матрицата.
    Успех!
    Да, има такова желание. С нетърпение очакваме публикациите. Който може - да помогне. Само имай пред вид вида на субпикселите на матрицата от линка.
    #3814
    върни се 2 поста назад- дал съм файл със сервизното меню на шаси N68 Samsung-новите модели
    както сам ще видиш някои модели имат резервен 2-ри вариант за LCD панел
    между другото преди седмица бях чел че на пазара има недостиг на стъклен субстрат-стъклените листи 0,7мм от които се правят матриците-така че може би разнообразието от матрици в един и същи модел е причинено от този недостиг-самсунг е принуден да купува матрици/панели/откъдето намери
  6. Member Аватара на adtomov
    Apr 2008
    #3815
    hristoslav2, какво ще кажеш за това, което ти написах за възможните алтернативи :
    http://forum.setcom.bg/index.php/top...html#msg363308
    Ето затова вярвам на Samsung дотолкова, колкото видят моите очи.
    #3816
    този от AVFORUMS -дали е имало разлика в изписаното на стикера отстрани и показанията в сервизното меню ??
    няма доказателство-трябва да постне снимки и на двете за да докаже
    самсунг ако си спомняш и миналата година слагаха каквото имат налично в моделите си
    надявам се изписаното на стикера да съвпада с монтираното /иначе егати компанията/
  9. Member Аватара на adtomov
    Apr 2008
    #3817
    Hristoslav2, Тази матрица я видях със с собствените си очи (под лупа), веке я има из цела BG, ПРИ КОД SQ01, трябва ли да напомням, пред всички, публикациите (във форума), в които съм ти казал че съм видял нова матрица с този код????
    Мммм? Или ти, като модератор, ще ги изтриеш. ??
    #3818
    дай да сменим темата че само спамим тук/пък и едва ли е интересно на всички останали/
    http://www.led-tv-prices.co.uk/sharp...-lcd-tv-r.html
    ето тук колегите италианци коментират новита шарпове
    http://www.avmagazine.it/forum/archi.../t-139967.html
    а тук колегите от германия правят същото
    http://www.hdtv-space-forum.de/sharp...s-t3596.0.html
    тук са англичаните
    http://www.avforums.com/forums/lcd-t...tv-series.html
    всички обсъждат новите неща -само ние с теб си обсъждаме някакви си матрици
    а тук колегите американци обсъждат явно любимият ти Samsung LNxxB750
    http://www.avsforum.com/avs-vb/showthread.php?t=1142350
    Jul 2009
    #3819
    По тъпи от англичаните не съм виждал :D
  12. Member Аватара на adtomov
    Apr 2008
    #3820
    ....всички обсъждат новите неща -само ние с теб си обсъждаме някакви си матрици
    Трябва да има и такива като нас - много добре го знаеш. МНОГО други имат полза от това. И не забравяй, че все някой ще диша в гърба. Ако не аз, то някой друг.
    P.S. Предполагам, че колегите съфорумци ще ни простят малкия спор off-topic
    #3821
    Цитат Първоначално публикувано от qbadabaduuu
    те и американците са си същите
    http://www.avsforum.com/avs-vb/forumdisplay.php?f=166
    Dec 2007
    #3822
    Някой може ли да ми обясни защо никъде не откривам в тех. хар-ки на ТВта какъв е нативният/статичен/ контраст.Примерно при покупката на моя телевизор - SAMSUNG LE-32A557 не можаха да ми кажат какъв е контраста/статичният/.Да не говорим че и обявеният динамичен контраст от 35000:1 не отговаря на истината - 15000:1.
    Благодаря!
    Nov 2001
    #3823
    Много моля някой от разбирачите тук да ми обясни разликите между следните два модела на Philips:
    42PFL5604 - 1,649.00 лв. и 42PFL5624 - 1,699.00 лв. И двата ги има в местния ТП, но ги няма в местния ТМ.
    Май, че ще се наложи да взема един от тях, ако не ми доставят поръчания LG 42LH4000. Впрочем, казаха ми, че е бил доставен, миналия четвъртък, но е бил с дефект като са го пуснали - с една червена линия отдолу и веднага поръчали друг.Ама аз минавайки в петък за справка бях толкова загорял за ТВ същата вечер, че след 2 часа чудене дали да чакам нова доставка - вдигнах ръка и посочих с пръст последния 42PFL7404 казвайки: 'Вземам го". Донесоха кашона и започнаха да го разкачат и.... като вадеха антенния кабел, буксата на антенния вход остана на кабелааа... , т.е. се откърти... По-голяма каръщина от туй не бях преживявал признавам си... Неописуемо е!!!
    Та май ако не стане пак доставката или има проблеми - остават ми само тия 2 модела приемливи 42PFL5604 - 1,649.00 лв. и 42PFL5624 - 1,699.00 лв. и искам да знам раликите между тях. За 42PFL5624 - 1,699.00 лв. ми казаха, че е модел специално за България, но нищо повече. тръгнах да ровя в нета, ама намирам инфо само на полски и то без технически характеристики, камо ли сравнения . Та дайте рамо, моля ви!
  17. Member Аватара на kaloman
    Sep 2008
    #3824
    Пич, извинявай, но мисля, че е тъпо да категоризираш така хората, при положение, че в техния форум има доста богата информация от потребители сменили по няколко телевизора! Е, сигурно трудно ще откриеш съвет от професионалист продавач- консултант да си гледаш телевизора на "студено", но това е друга тема!
    Jul 2009
    #3825
    kaloman
    Едиснтвено англичаните се обаждат и казват че телевизорите не работят а те не са ги настройли.
    Казах конкретно за Philips че бялото е най реално при "студено" но явно ти ги разбираш нещата. Да ти дам телефона на някой от търговските на Philips да ги светнеш и тях какво предлагат?
    stekyman
    Philips:
    42PFL5604 - 1,649.00 лв. и 42PFL5604 - 1,699.00 лв.
    Този от 1,699.00 лв да не би да е 42PFL5624?
    От toddy във форум Телевизори
    Отговори: 5360
    Последно: 03-12-10, 11:16
    Отговори: 4485
    Последно: 31-12-08, 22:00
    От LUDIA във форум Телевизори
    Отговори: 3340
    Последно: 31-12-07, 18:35
    Отговори: 560
    Последно: 17-10-07, 23:50
    Отговори: 96
    Последно: 29-12-05, 15:19
