Страница 151 от 300 ПърваПърва ... 101141149150151152153161201 ... ПоследноПоследно
Резултати от 2,251 до 2,265 от общо 4486
Помощ за избор на LCD/Plasma телевизори - 2008
    Dec 2007
    #2251
    Re: Помощ за избор на LCD/Plasma телевизори - 2008
    lazarus18,Попкорна може ли да се ползва като ъпскалер т.е.през него да преминава видео сигнала от цифровия приемник и да мога да му сменям резолюцията?
  3. Moderator
    Aug 2006
    #2252
    Цитат Първоначално публикувано от KonanVarvarina
    Не, той няма видео вход.
    Теоритично би могло да стане ако прекарваш сигнала през компютъра и да стриймваш от там в реално време, което ми се струва прекалено сложно и не виждам смисъл.
    #2253
    bdm Благодаря за инфото-за съжаление има да чакаме този формат
    2160p is the shorthand name for the next step and the future of HDTV video modes. It has a resolution of 3840x2160. The number 2160 stands for 2160 lines of horizontal display resolution, while the letter p stands for progressive scan or non-interlaced. In a progressive image the lines of resolution of the image go from the top of the screen to the bottom.
    2160p is also called "Quad HDTV" since it displays four times the number of pixels of the highest HDTV standard resolution, 1080p. Quad Full High Definition (QFHD) is the next step in high-resolution display technology, and won't start shipping until 2015. The only step higher in television technology is Ultra High Definition Video.
    Everytime we hear about QuadHD, we just picture four high-def panels held together by duct tape in a two by two configuration. Luckily for you, we're not HDTV designers. We'll leave that to the folks at Chi Mei Optoelectronics since they can get 3840x 2160 resolution on a single LCD panel and will be modeling it at CeBIT next month. Before we get the "that's only double the res of 19801920x1080i" comments, make sure you do the math both on the x- and y-axis, as our geometry teachers loved to say.
    Granted, we don't yet have a signal for a QuadHD TV and it's likely we won't for a while since we're working on the final three years of our DTV transition, but could you just imagine playing Fight Night 3 on an 8.3 megapixel screen? We'd be down for the count for sure.
    C'mon, who hasn't had an inexperienced movie goer over that politely asks why black bars still show up on a widescreen HDTV? Have you ever wondered if a set would be produced to harmonize with those films shot and presented in 2.35:1? Sound & Vision sat down with a number of industry experts and asked them that very question, and while many believe that the same technology that has become commonplace in custom projector installs is feasible for TVs, it's not apt to happen anytime soon. Essentially, there's just not a large enough market for ultra widescreen displays; the hardcore among us that would spring for one are in the minority. Richard F. Doherty, research director of The Envisioneering Group on Long Island, was one fellow who seemed to have more faith than anyone else, even going so far as to suggest that we may see at least a prototype of one such set at CES 2009. Mark our words, we'll be keeping an eye out -- after all, it shouldn't be too hard to spot in the sea of 16:9 units
    Nov 2003
    #2254
    Цитат Първоначално публикувано от RCS
    ми и в метро струва 1600 и няколко лева, снощи го видях (Метро Пловдив)
    В Метро Търново е на 1198лв с ДДС, иначе е 999лв без ДДС-то. Имаха даже няколко бройки, но в крайна сметка се доверявам на мнението на lazarus18 и ще изчакам за нещо друго.
    #2255
    Я сега да хвърля една тема за размисъл във форумният "ефир".....какво мислите за това дали да има UPS към LCD или към плазмата? Когато излезнаха плазмите беше препоръчително да имат.......за LCD-тата не знам как стоят нещата. Но имайки в предвид все по-честите спирания на захранването и големината на пусковия ток.......не знам ........може би има нужда. Ползва ли някой и ако е така нека да разкаже. И понеже темата е Плазма/LCD, мисля, че тук е местото да се коментира
  7. Junior Member
    Sep 2007
    #2256
    Въпроса ти е дали има вграден или има ли нужда от външен?Повече се притеснявам от бурите с гръмотевици от колкото от токовите удари за мен лично,а хората работещи в гаранционните сервизи биха дали най точна информация за гръмнали ТВ-та от токови удари.
  9. bgm
    bgm е офлайн
    Member
    Dec 2006
    #2257
    Вместо UPS можеш да си вземеш разклонител с защита от пренапрежения и гръмозащита от ТТ. Към 30 лв.
    May 2008
    #2258
    Тия разклонители не вършат никаква работа, ако ще и за 100 лв да е. Един кадърен токов удар и си си отишал като стой та гледай. Малките колебания в тока дето това ще улови така или иначе не могат да ти навредят особенно.
  11. bgm
    bgm е офлайн
    Member
    Dec 2006
    #2259
    Напротив вършат чудесна работа.
    Когато изходният ток надвиши входния с
    определено делта (примерно при гръмотевица), се включва защитата.
    Естествено не говоря за китайски самоделки.
    Вместо разклонител можеш да си вземеш и такъв предпазител.
    Цената му е около 25 лева.
    С такъв, колега си спаси живота от китайски бързонагряващ бойлер.
    Mar 2008
    #2260
    Цитат Първоначално публикувано от bgm
    какво визираш под предпазител?
    то при токов удар, входния и изходния ток са ти равни бря... нещо не разбирам какво имаш предвид.
    Едит: това дето е ползвал колегата ти, най-вероятно е било дефектнотокова защита, което е друго нещо.
    #2261
    Някои основни правила:
    1.При гръмотевична дейност - щепселът на каквато и да е апаратура (без хладилника) се изключва от контакта!
    2.По същият начин и с антенният вход на телевизора/тунера и особено кабелната.
    Няма кой-знае какво да загубите, ако не гледате нещо в този момент. А виж, самата техника е много вероятно да се повреди!
    Колкото до разклонителите със защити. Много важно е за правилната им работа да имате трипроводна инсталация и читаво заземление, по което да се отвежда енергията. Иначе не се ползва пълният им капацитет.
    Освен това защитният елемент си има също капацитет и след преминаване на по-мощен импулс, следващият може да си протече директно през техниката, която защитава. По тази причина на качествените защити има индикатор, указващ, че е време да се смени елемента на защитата.
    Лично аз за PC ползвам един на MGE 6x Шуко, 3500W, зашита от деца, прекъсвач и индикатор. Струваше ми точно 24 лв. преди 14 месеца и с 2 години гаранция на производителя. До момента не съм имал проблем. Единственият му недостатък е 1,8 м кабел, защото е правен по английската система за дължина и е около 6 фута.
  15. bgm
    bgm е офлайн
    Member
    Dec 2006
    #2262
    Цитат Първоначално публикувано от ethernall
    Дефектно-токова защита имам предвид. Точно така.
    При гръм и индукция няма как да си ти равни
    входния и изходният ток и точно на този принцип
    се прави тази гръмозащита.
    Не съм най-големият специалист в ел. защита,
    но все пак като инжинер си имам някаква малка представа.
    Dec 2007
    #2263
    Не вярвам дефектнотоковата защита да те спаси от гръм и пикове в напрежението. Тя сравнява входен и изходен ток по проводниците. Образно казано - к'вото влиза през фазата да излиза и през нулата.Ако не са равни - изключва. Сиреч, ако ти гръмне китайския боилер и фазата започва да "утича" през снажното ти тяло към водопровода , то двата тока вече не са равни заради утечката. Ако "индукцията" е преди защитата според мене нема да трепне даже. Ако е след защитата, т.е. се явява като утечка - има шанс. ОБАЧЕ - веремето за задействане по принцип май е колкото да спаси човешки живот. Сиреч - техниката може да е заминала вече, особено електрониката. Все пак ако има някой "гуру" - нека каже и той.
    Mar 2008
    #2264
    Мда ако говорим за индукция по кабелажа вътре в апартамента - може и да стане номера. Въпроса обаче наистина е колко е времето за реакция - по БДС не трябва да е над 0,4 секунди, сега някой, който рабира от да каже за колко време думка телевизора
    Dec 2007
    #2265
    Май не е зле да се върнем към телевизорите а? Може би една нова темичка - Защита от пренапрежения - и там?
    От toddy във форум Телевизори
    Отговори: 5360
    Последно: 03-12-10, 11:16
    Отговори: 6640
    Последно: 01-01-10, 20:30
    От LUDIA във форум Телевизори
    Отговори: 3340
    Последно: 31-12-07, 18:35
    Отговори: 560
    Последно: 17-10-07, 23:50
    Отговори: 96
    Последно: 29-12-05, 15:19
